TwinTurbo.NET: Nissan 300ZX forum - The cut off wheels works better with the dremel if...
Ashman2k2
on December 05, 2005 at 6:28 PM
How to Replace Fuel Injector Using Dremel Method
posted by robo (sebring1970)
on December 05, 2005 at 07:15 AM
you are careful with ure hand motion moving the dremel up and down with the arc of the wheel carving into the plenum..I found that the tungsten carbide wheel would very easly clog up with the aluminum from the plenum. Nice job btw :)
robo (sebring1970)
07:15:43 12/05/05
Nice writeup! VTF (n/m)
Tom B (IN)
07:26:13 12/05/05
faqit! (n/m)
E=mz²
08:00:15 12/05/05
Add the part about relieving the fuel pressure first. (n/m)
Woody75 (Denver)
09:00:00 12/05/05
2nd! One way it can be done is by removing fuel pump relay
doug8867
09:12:23 12/05/05
Agreed. Although removing the fuel pump fuse
Luis (San Antonio)
16:07:06 12/05/05
ConZult has a feature for relieving fuel pressure
Tom B (IN)
22:45:24 12/06/05
good point. I didn't relieve any fuel pressure before
robo (sebring1970)
10:28:19 12/05/05
Big step
Mickie
11:41:14 12/05/05
hmmm, wouldn't that solve one of the hardest parts of
robo (sebring1970)
03:07:20 12/09/05
that's an awesome job of documentation...
Audioquest
09:42:18 12/05/05
How to Replace An Injector that NEEDS the Dremel Method...
thumper300zx
10:10:23 12/05/05
Yeah, I read this when I did #6 a month ago..thanks! (n/m)
Audioquest
10:53:16 12/05/05
I'm happy to have your article tag along in this FAQ
robo (sebring1970)
12:15:12 12/05/05
The cut off wheels works better with the dremel if... -
Ashman2k2
18:28:43 12/05/05
Nice write-up but NO FAIR. These injectors already had the
jzack
18:33:53 12/05/05
Stock screws are very easy to remove if you use a both a
Julius
18:42:37 12/05/05
A manual impact wrench works great too!! (n/m)
Zirvana
13:08:01 12/06/05
curious, how/what kind of adjustable wrench can/do you
robo (sebring1970)
03:06:16 12/09/05
He's probably got a square shafted driver and uses...
thumper300zx
08:43:06 12/12/05
Several things....
sorka
02:27:43 12/06/05
yes, purists will always rec pulling the plenum.
robo (sebring1970)
20:25:46 12/06/05
look for any corrections to this article on my Web site
robo (sebring1970)
18:22:41 12/08/05
